Visualization
Cineware by maxon add-on has unexpectedly closed.
Arch Introini
I have Archicad 27 Build 5030 and when i render something sometimes i have this error: Cineware by maxon add-on has unexpectedly closed.
Even with Build 3001 i had the same problem.
It's very frustrating, could someone help me please?
Operating system used: Mac Apple Silicon Sonoma 14.5
16 REPLIES 16
Try clicking on "Done".
Replacing the folder should work.
From Archicad 17
MacBook Pro M1 Max
I clicked on "Done" but I get the same message the next time that I start ArchiCAD.
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
Redshift is another rendering plugin of Archicad and if am not mistaken it should be subscription base.
WINDOWS 11 PRO
I have seen no mention of it being subscription only.
But it is certainly hardware dependent.
@Barry Kelly not sure if this link helps.
https://help.graphisoft.com/SOLO/27/INT/_AC27_Help/143_Redshift/143_Redshift-1.htm
WINDOWS 11 PRO
That says you need an SSA/Forward support agreement, which is different from collaboration subscription, which is what I thought you meant.
So, for Redshift you need to have a current support package as well as the hardware to run it.
I had the same message pop up when I replaced the Cineware folder that Karel Landa uploaded.
I use a Mac, so opted to 'move to trash' as Redshift isn't compatible with MacOS anyway.
The error message doesn't show up anymore and Cineware is working perfectly now.
Thanks everyone!
Setup info provided by author
