Visualization
Cineware renderer quits in ArchiCAD 28
svpribyl
I just downloaded and installed ArchiCAD 28 and I get the same message regarding Cineware rendering engine quitting that I got with the 28 Technology preview:
Operating system used: Mac Intel-based
ā€ƒ
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
44 REPLIES 44
Did that as well. No luck.
I attempted another solution which was to install a fresh copy of Archicad on a separate partition running macOS 14.8.1 Sonoma, and then running Archicad from that partition. This solved the problem, and I was able to render with Cineware successfully!
I then backed up and reformatted my entire hard drive and downgraded to OS 14 and reinstalled Archicad again with the same result. So there appears to be a conflict between OS 15 Sequoia and Maxxon.  Just thought I would let people know that this is a workaround, albeit not an ideal one, but it does allow you to render, which was crucial to me.
Lee Hankins
It is an issue with macOS Sequoia. I’m running Sequoia and Tahoe which had the same issue but replacing the Cinerender folder and removing the Redshift folder from within resolved the issue for me and Conetender Cinerender works on both systems with both intel and M processors.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
I am still having this issue. I just installed the new cinerender file from the link. I also deleted the webroot application because there was some talk that it might be the culprit. That did not help either.
Steve
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
Lee Hankins advises to delete the 'Redshift' folder from within that 'Cinerender' folder and says that works.
https://community.graphisoft.com/t5/Visualization/Cineware-renderer-quits-in-ArchiCAD-28/m-p/679737/...
We have Webroot installed on our system and Cinerender still works.
Lee Hankins
macOS Tahoe (26.0)
Once you’ve deleted the Redshift folder you just need to make sure not to select the ā€˜Redshift’ rendering engine inside the photorendering window settings. If you do Archicad will hang for ages and then default back to Cinerender. I believe this is all planned for a fix in Archicad 30.
Lee Hankins
macOS Tahoe (26.0)
To be nit picky it is an issue with Cinerender not with Sequoia. This is on GS not on Apple to fix.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Yes that’s correct. That’s why Graphisoft have said they are fixing the issue in Archicad 30.
Lee Hankins
macOS Tahoe (26.0)
Hi Karel, his link seems not functioning anymore. I am workin on MacOS Sequoia (intel processor). Problem with Archicad 29 and 28 before: I should fix them both. Could you please post another link? Thanks!
Setup info provided by author
