Visualization
Composite wall not showing properly in 3D
rm
Hi everyone -
Something going on here in 3D views using AC 22 that I just cant seem to correct. In the attached image, I have circled the end wall condition of a composite wall that is showing the skins. I want it to be shown as a solid surface with no skins showing through, as it should display.
I have also attached the screen shot of the makeup of the composite wall. Do any of you see something I am doing wrong here or is this a shortcoming in AC 22 to properly display composite walls in 3D. Im guessing I am doing something wrong here.
Thank you!
Robert Mariani
MARIANI design studio, PLLC
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
13 REPLIES 13
agroni
Try using a Wallending from the Toolbox. With it you can define the length of the ending including the material.
In the attachment you see one wall without the ending the the right one with the ending.
The BIMster @ AllesWirdGut
Currently: Archicad 26
User since Archicad 6.5 (2001)
rm
I have attached a screenshot from the toolbox. Wall Ends is selected, if that is what you mean, it is not making a difference.
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
Guru
Wall End is a separate tool. It is located under "More" by default.
Ling.
Win10 | R5 2600 | 16GB | GTX1660
rm
Ling -
Thank you. In my case, that seems to solve one problem and then creates a new one. A line is showing up between the end wall and the wall it is attached too. That is not the desired effect. I cant seem to figure out the correct settings to get rid of the unwanted line. Any suggestions?
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
rm
Ling -
You have to select "set to wall height" to get rid of the separating line. But you probably knew that. Thanks again for pointing me to the right tool!
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
Have you tried just overriding the wall end surface material?
This will make it a single surface.
rm
Barry -
That looks like another solution, that would be even easier yet in 3D and certainly simpler. However, wouldn't you loose the composite wall lines in plan view? I will give it a try.
Thank you!
Robert Mariani
Mac OSX 13.1
AC 24 / 25 / 26
No, this just affects the surface material in 3D/elevation.
Guru
You will not have your skins wrapping in plan using the edge overwrite.
Ling.
