Visualization
Displacement - Triangulation Issue
derekjackson
I'm playing around with CineRender's Brick shader, and trying to get some convincing results when using it in conjunction with Displacement.
I've just done a test render and there seem to be some real oddities. The shadows between the bricks appear larger and blurred in certain areas (boxed in red). There's also a weird diagonal artefact on the first floor. The wall is one consistent element, yet the change seems to be related to window position. I can only assume it's something to do with how the wall is triangulated at render time.
Has anyone else had this? Is it a PhotoRendering setting that I've got wrong, or a bug of some sort? Any advice welcome!
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
8 REPLIES 8
Erwin Edel
How big of a displacement are we talking? I generally start modelling anything from 10 mm up. The few times I've tried displacement the render times were rediculously long.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
derekjackson
10mm. Render took about 3 hours, so using Displacement seems plausible for the odd shot - if it looks okay!
AC19 / 21 / 23 / 27
Erwin Edel
3 hours is too long for me
We do a lot of renders for clients and try to keep them at around 5 mins max for exteriors, where we finish things off with a bit of photoshop.
Creating a pattern in a complex profile won't take very long and the render without displacement will be fast.
I did notice some weird behaviour when I was still trying stuff out with cinerender around AC18 times to get to a mode where we are now with render times nice and fast and decent enough results.
I think the best results were with creating a morph plane with subdivision that sat on top of the actual surface. It's been a few years, so maybe someone else who is actually using this stuff can shed more light on the subject.
www.leloup.nl
Windows 10 Pro
derekjackson
Hmm - a morph plane would be a major hassle, given that we're still shuffling window positions around.
Shame that the Displacement shader can't be relied upon - the bits that worked look great!
Has anyone found a way around the issue via settings in the Displacement shader options?
AC19 / 21 / 23 / 27
Erwin Edel
Thinking back this might have been sub polygon displacement.
Just had a look at the help for this: https://helpcenter.graphisoft.com/user-guide/77481/
Not overly thrilled by the results for bricks there. Edges are too rounded / soft to be believable, IMO.
www.leloup.nl
Windows 10 Pro
derekjackson
Well I'm trying the sub-divided Morph plane trick to see if that works. I can always up the SPD number too...
Yep, the rounded bricks don't look too good up close, but it should work well from a distance - mortar shadows relating to sun position, nice silhouettes on building edges, etc...
AC19 / 21 / 23 / 27
Lingwisyer
Guru
If you use a Normal map instead, I do not think you get the rounded effect.
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
derekjackson
True, but you don't get the nice silhouette either...
AC19 / 21 / 23 / 27
