2007-10-31
02:14 PM
- last edited on
2024-07-05
11:56 AM
by
Aruzhan Hamar
2007-10-31 04:17 PM
2007-11-01 08:52 AM
2007-11-01 06:57 PM
Fredrik wrote:Could you give a detailed description of what you mean by changing the style?
When we want to switch from one style ona a wall to another style then the draftsman should simply select the new style from "Favorities" be able to use the Format Painter tool.
2007-11-06 03:37 PM
2007-11-06 05:02 PM
2007-11-08 09:49 PM
2007-11-09 03:34 AM
Ignacio wrote:Excellent - thanks for adding that, Ignacio!
You may already be aware of this but just in case --since you have the 'wall style' saved as a favorite, all you need to do is select the walls you want modified and double-click on the favorite.
Because since AC 10 or so you have 'parameter exclusions' for favorites, you can turn off the 'injection' of height, story 0, offset, ID and layer if you want, which actually you cannot do with the syringe.
