Visualization
Glass material not showing as transparent?
I have opened up an older archicad file for a project that our office did several years ago. I have now opened the file up in Archicad 16, and the glass material is not showing as transparent. I have been into the material settings, selected the right glass material, and have adjusted the transparency etc, but no chance. Any ideas?
Thanks
5 REPLIES 5
Have you checked in 3D Window Settings that Transparency is on?
Fran_ois Chatelain
And also make sure the transparency is set to over 70% in the material settings.
Cheers
Francois
François Chatelain
Worldwide Digital Imaging
Formerly posting as RanXerox
"A little bump will help blur your reflections"
David Maudlin
In my experience a Transmittance setting of 51 or more will make the material transparent in the 3D Window.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Fran_ois Chatelain
Hi David,
you're right.
Mind you, I didn't bother checking before posting, I was referring to previous behaviour in older versions 😉
Cheers
Francois
François Chatelain
François wrote:
Hi David,
you're right.
Cheers
Francois
The 51% threshold has been the rule for as long as I've been using ArchiCAD. Perhaps you mean before version 3? 😉
