2013-04-08
04:56 AM
2023-05-11
01:51 PM
Noemi Balogh
2013-04-08 06:16 AM
2013-04-08 02:11 PM
2013-04-08 02:33 PM
François wrote:In my experience a Transmittance setting of 51 or more will make the material transparent in the 3D Window.
And also make sure the transparency is set to over 70% in the material settings.
2013-04-08 05:37 PM
2013-04-08 06:01 PM
François wrote:The 51% threshold has been the rule for as long as I've been using ArchiCAD. Perhaps you mean before version 3?
Hi David,
you're right.
Mind you, I didn't bother checking before posting, I was referring to previous behaviour in older versions😉
Cheers
Francois
