2016-09-23
10:41 PM
2023-05-11
03:52 PM
Noemi Balogh
2016-09-24 05:07 PM
2016-09-27 03:20 AM
mc0m wrote:Switch to your floor plan view and then go to the 'WINDOW' menu and choose 'Close All Background Windows' - but make sure you have saved any you do want to keep.
... whether or not to save each rendered image when I close a tab?
I do a lot of quick partial renders to check stuff in 3D, and don't want to save them. It is aggravating and disruptive to have to tell it tonotsave every single one of them.
I'm unable to find how to disable this in the program - does anyone know?
Many thanks in advance to anyone who can help.
2017-09-17 11:10 PM
2017-09-18 03:07 PM
2017-09-19 09:54 AM
DGSketcher wrote:That's partially of what I miss from using VRay on 3dsMax. Being able to render over selected parts of your last render / catalogued renders... It allows you to re-render just parts of a scene that have changed as well as create test shots at 100% of select regions.
Rather than AC generating a new picture every time, how about it only ever creates one rendered image and overwrites it if it hasn't been saved or created as a separate tab?
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2017-09-19 01:48 PM
Lingwisyer wrote:You can use the Marquee Tool on the 3D Window to render just a select region.
... as well as create test shots at 100% of select regions.
2017-09-19 03:05 PM
2017-09-19 04:42 PM
