‎2004-05-18
06:33 PM
‎2023-05-11
03:37 PM
Noemi Balogh
‎2004-05-18 06:36 PM
‎2004-05-18 08:22 PM
‎2004-05-18 08:29 PM
‎2004-05-18 09:21 PM
ashley wrote:I think Niel McCann's D3 Library (AKA Real Doors) can do this. The feature has to be written into the library part. It also requires that the model is rebuilt for each frame of the fly-through.
how to set the door open during the rendering?
When the camera get close to the door it open, and when camera move away it will close by itself.
‎2004-05-18 09:44 PM
Matthew wrote:... and it also requires to render in ArchiCAD, which IMHO at the moment is only feasible with AV Works or sketch rendering. But, leave it running through a long vacation ...ashley wrote:I think Niel McCann's D3 Library (AKA Real Doors) can do this. The feature has to be written into the library part. It also requires that the model is rebuilt for each frame of the fly-through.
‎2004-05-18 10:45 PM
Djordje wrote:If you want to go outside of ArchiCAD and animate stuff (as I've said elsewhere) Cinema 4D will do anything you want. You can open the doors as you approach, or make them evaporate, or they can cringe, scream and run away from you.Matthew wrote:... and it also requires to render in ArchiCAD, which IMHO at the moment is only feasible with AV Works or sketch rendering. But, leave it running through a long vacation ...ashley wrote:I think Niel McCann's D3 Library (AKA Real Doors) can do this. The feature has to be written into the library part. It also requires that the model is rebuilt for each frame of the fly-through.
‎2004-05-19 10:10 AM
‎2004-05-19 01:07 PM
‎2004-05-19 11:15 PM
