Tom Krowka
Photorendering setting toolbar
Hey....for some reason photorendering settings dialogue box won't show up. Was working fine until yesterday. For some reason.....no show. Have minimized AC, thinking it might be behind the window....no go. Have rebooted thinking it's the video card memory Did not help. Every thing else seems to be fine. Any ideas?
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
1 Solution
Minh Nguyen
Hi Tom,
Thank you for the question!
I'm wondering when you open the palette, does it freeze Archicad, or it just does not appear anywhere? If the later is the case, I'm afraid that the dialog has been pushed off the screen by accident. Are you having multiple display setup?
I would like to suggest trying the following things:
(your account on Windows needs to be Administrator type, and ARCHICAD need to be closed before taking these steps)
- Go to C:\Users\[your account name]\AppData\Roaming\GRAPHISOFT\ARCHICAD XXXX\ then delete the file ARCHICAD Basic.prf
If it doesn't work, then:
- Open Registry Editor by right-clicking on Start button, select Run. Type regedit then press OK.
- Go to the following directory: HKEY_CURRENT_USER\Software\GRAPHISOFT\ARCHICAD\ARCHICAD XXXX\Dialog Manager Custom Data, then delete the file RenderingSettingsPaletteRect
(XXXX is the version of ARCHICAD on your computer)
Sometimes a computer restart may help with the issue!
Let me know how it goes for you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Go to post
7 Replies 7
Did you try Menu > Windows > Palettes > Photo Rendering Settings?
Tom Krowka
Yes. When I select it I get the hourglass symbol bot no dialogue box.
[email protected]
www.walshkrowka.com
Strange... Perhaps updating your graphics card drivers...
Minh Nguyen
Hi Tom,
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Tom Krowka
Thanks for the prompt reply. Dialogue box simply doesn't appear. Am using two displays, but occurs when using only laptop. Rebooting computer did work once, then had problem again. Seems to work fine on multiple display.
Will keep your solutions on hand in case it happens again.
Thanks Tom
[email protected]
www.walshkrowka.com
runxel
There is actually another way: editing the workspace xml.
Tom Krowka
Go to work environment solution is the way to go. Thanks for the tip
[email protected]
www.walshkrowka.com
