‎2023-11-14
03:45 PM
‎2023-11-15
11:50 AM
Hi there,
I'm looking for rendering setting (photorealistic rendering) with Renderer: Redhift.
a) for Daily outside
b) for Daily inside
c) Night outside
d) Night inside
All with lamp and light
ArchiCAD Tutorials only shows the menu and buttons, but no example setting........
‎2024-05-02 05:24 PM
Hi Andreas! Make an archice, pla-file, of your project. Zip it and post it here. That will make it easier to spot what's wrong.
‎2024-05-02 06:14 PM
‎2024-05-06 08:59 AM
You did not include your Archicad file in the folder so it's hard to search for errors. But maybe you should check the following:
‎2024-05-06 10:06 AM
Hi Karl, do you have an example from yourself with screenshots etc, how to do?
‎2024-05-06 10:11 AM
‎2024-05-06 11:36 AM
Its easier if you save as an archive file with .pla as file ending.
‎2024-05-06 11:44 AM
‎2024-05-06
04:54 PM
‎2024-05-09
12:00 AM
If I open your file and , for example, choose, the HDRI " Bäume 01 GS.hdr" in the german library I get the following result. The first interior is with only HDRI, the second is with lights switched on. You can try different HDRI:s, add or remove lamps and change the materials to experiment how this affects the render.
‎2024-05-06 05:12 PM
Ok, i will try, thx.
PS:
the file is a test object 😉
