2023-11-14
03:45 PM
2023-11-15
11:50 AM
Hi there,
I'm looking for rendering setting (photorealistic rendering) with Renderer: Redhift.
a) for Daily outside
b) for Daily inside
c) Night outside
d) Night inside
All with lamp and light
ArchiCAD Tutorials only shows the menu and buttons, but no example setting........
2024-05-02 05:24 PM
Hi Andreas! Make an archice, pla-file, of your project. Zip it and post it here. That will make it easier to spot what's wrong.
2024-05-02 06:14 PM
2024-05-06 08:59 AM
You did not include your Archicad file in the folder so it's hard to search for errors. But maybe you should check the following:
2024-05-06 10:06 AM
Hi Karl, do you have an example from yourself with screenshots etc, how to do?
2024-05-06 10:11 AM
2024-05-06 11:36 AM
Its easier if you save as an archive file with .pla as file ending.
2024-05-06 11:44 AM
2024-05-06
04:54 PM
2024-05-09
12:00 AM
If I open your file and , for example, choose, the HDRI " Bäume 01 GS.hdr" in the german library I get the following result. The first interior is with only HDRI, the second is with lights switched on. You can try different HDRI:s, add or remove lamps and change the materials to experiment how this affects the render.
2024-05-06 05:12 PM
Ok, i will try, thx.
PS:
the file is a test object 😉
