on
2022-07-14
03:00 PM
- edited on
2023-05-15
02:41 PM
by
Noemi Balogh
Our users’ essential wish was to update the Additional Surface Catalog. The previous catalog did not fully support the new rendering capabilities within Archicad with the default settings, which required more manual workarounds. In addition, the surfaces in the catalog were not always suited to follow the latest residential and commercial design trends.
The Additional Surface Catalog is one of the many benefits offered to our Graphisoft Forward and SSA customers. The Additional Surface Catalog, containing several hundreds of surfaces, has been completely renewed with Archicad 26.
It works the same way as before: you load the Additional Surface Catalog into your active project libraries and import the necessary surfaces into the attribute set.
The Additional Surface Catalog for Archicad 26 is entirely new. This is what you need to know about it:
Use the renewed surface catalog to create better and modern visualizations of your design intent for faster approval from your clients.
Learn about all the new visualization features of Archicad 26:
To learn more about all the new features of Archicad 26, read this article.
