‎2007-05-24
01:43 PM
‎2023-05-11
01:54 PM
Noemi Balogh
‎2007-05-24 03:34 PM
‎2007-05-24 03:39 PM
‎2007-05-24 03:47 PM
‎2007-05-24 06:56 PM
Dwight wrote:nope that didn't work. I will try rotating it in Photoshop and see if that will get around the problem.
See if angle = 180 helps.
‎2007-05-25 03:56 AM
fuzzytnth3 wrote:Angle 90° perhaps?Dwight wrote:nope that didn't work. I will try rotating it in Photoshop and see if that will get around the problem.
‎2007-05-25 10:24 AM
Barry wrote:That's where I started as you can see in the settings screenshot above. Pretty much any angle you set it to the texture doesn't budge an inch
Angle 90° perhaps?
Wouldn't 180° flip the texture completely upside down?
‎2007-05-25 12:06 PM
fuzzytnth3 wrote:The angle for your internal engine is 90° and appears to have rotated the texture correctly.Barry wrote:That's where I started as you can see in the settings screenshot above. Pretty much any angle you set it to the texture doesn't budge an inch
Angle 90° perhaps?
‎2007-05-25 12:11 PM
