Take a look at give some advice on how to improve this rende
Hi
I have rendered this in Lightworks and would like some advice on how to improve this render.
It will ultimately become a billboard on site. It is still missing some louvers on those balconies and i will eventually photoshop it into the site, so ignore the pavement and the road.
For example how would I be able to get an environment into the windows facing the street? I usually do this in photoshop manually but maybe there is an answer?
THanks a lot!!
23 Replies 23
I agree with what you are saying about those software people (no disrespect..) but luckily it will be up high above a hording on site 1mx2m in size so i hope you won't be able to see them.
I also agree what you guys said about the shadows and sun etc. but i had bad luck with the weather on the day i took the sitephotos. I have attached it so you can see what i had to use for this.... unfortunately London is not famous for its long sunny days.
I am glad you guys like it though... thanks for your comments.
The reason why this is a landmark for me is because i am used to using FormZ or 3Dmax for rendering, and i wanted to see what i could achieve with AC. What LW lacks in quality it makes up in ease of use and speed.
I will use only LW from now on.
I do wish one would be able to save different LW setup preferences...
With that photo you've done well. I spent 8 years in London, '89 was a good summer, then they got steadily worse every year that followed, so I can understand what you're up against.
Dwight
That background photo is no problem at all - you can easily drop in a nice sky. The fact that Britain is made from finely detailed buildings ruined by the hrashness of a sunny day, when you do take a photo on a cloudy day, the context has a better chance of looking the same as your rendering, because renderings tend to have more detail than context photos.
Dwight Atkinson
Master Dwight
Did you see that earlier in this thread i have replaced the sky?
Your humble Light works peasant...
Dwight
duh. i am running a little fast and loose right now...
Dwight Atkinson
patricprz wrote:
This is how far i got so far... again please comment if you want!
Very good progress! Congrats.
Dwight
Now that I actually see the image you refer to, it having appeared on a prior page that the one I saw intially, this image is a great start, but the overhanging shadow is a bit ominous.
beautiful glass - how do you get the deep blue?
try putiing a full power general light into the shot with a start and end light intensity matching the overhanging shadow distance. golden color.
Dwight Atkinson
finally got maxwell..... dunno how to use it yet but this is the first test i have done yesterday.
Now that's more like London...
Another one in rendered in MW.
