ā2010-05-23
02:32 PM
ā2023-05-11
03:53 PM
Noemi Balogh
ā2010-05-25 12:57 AM
Dwight wrote:Haha
They take off points for using Illustrator.
They can tell, those tricky professor types.
ā2010-05-26 04:54 PM
ā2010-05-26 06:06 PM
NStocks wrote:It's too hard to tell from the attached image, primarily because it has been rendered at such a low resolution. Any chance you post an original PDF somewhere?
If you have a PDF of your work, do your lines look similar to these or are they more crisp. ( I realise the uploadmaybe lower quality )
ā2010-05-26 06:37 PM
ā2010-05-26 09:28 PM
Ralph wrote:The lines look a bit rough. They look as if someone has taken sandpaper to the edges and removed the sharp, crisp line. I don't have my Mac with me but I will see if I can find the backup and possible upload a PDF to yousendit.com...NStocks wrote:It's too hard to tell from the attached image, primarily because it has been rendered at such a low resolution. Any chance you post an original PDF somewhere?
BTW - when you refer to the crispness of the lines, do you mean that lines look pixelated? Or does the antialiasing look a bit rough? Or are the lines too thick?
ā2010-06-06 05:16 PM
ā2010-06-07 02:55 PM
PB wrote:That's something I will have to look into. I'm not sure how that would work though, since my printer only does A3 sheets. or oversize A3 on a roll. I would need to look how ArchiCAD deals with this.
Just to go back to your logo issue: Can you generate your drawings to a size that fits across two A3 sheets - with only the unwanted logo on the second sheet: You then print only the desired sheet?
P.S. Out of curiosity, which University are you studying at (if you don't mind divulging such info!)?
ā2010-07-02 05:44 PM
ā2010-07-02 06:11 PM
