Visualization
Twinmotion surface textures appear all blue and empty. Please help
Planner JM
I imported this file into twinmotion but surfaces seem to be blank. Both using direct link and manual import. Other features such as skydome are visible but every other texture appears blue. Anyone who knows how to fix this please?
Operating system used: Windows 2024.1.2
4 REPLIES 4
Planner JM
Somebody help, please
Kotetsu
It's not a fundamental solution, but how about trying to export it in FBX format?
▼ウィッシュリスト(投票が集まるとGSの検討対象になります。賛同してくださる方は投票をお願いします!)
ひとつひとつの線の線種/色/表示非表示を変更できる機能(ラインワーク) | 「線として表示」としてもBIMx上で通り芯を表示 | 部材の始点/終点座標を一覧表とプロパティで取得 | 通り芯と要素の連動 | 表現の上書きに数式
Win10 / 13th Gen Corei7 / 32GB RAM / RTX2000Ada Laptop
AC17 - 27 / ACUG
Planner JM
My question is why are the starting plane, cylinder and sphere blue. Looks like something is wrong with materials and surfaces. Check the  screenshot.
Guru
Looks like a zdepth map. Check your preview settings.
Regarding the textures at the bottom, are the TM ones like that as well? If so, probably better of asking over on the TM forums.
Ling.
Setup info provided by author
