Visualization
fly-thru cameras renumber themselves
Erika Epstein
When placing cameras for a fly through, as I adjust them they often renumber themselves and it is a time-consuming process getting them reordered correctly.
What I've not been able to figure out is what I am doing that they renumber; anyone know?
Thanks
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
4 REPLIES 4
Curious. I have seen some quirky behavior with the cameras but don't recall any spontaneous renumbering.
Erika Epstein
It's only when adjusting placed cameras for fly-throughs.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
I had trouble with the spontaneous rearranging of cameras in fly-through paths.
I've found that if I want to add a camera to the end of the path, I need to select the last camera that in that path, and then select the camera tool, and then place a new camera. In other words, the new camera seems to be added after the one that is selected, but if I do not select any camera, I have no idea what logic ArchiCad uses to determine where to add the new camera.
David Maudlin
Playing with this a bit, it looks like ArchiCAD remembers the last selected camera for determining where in the sequence to place a new camera, even if the user does not remember. So the reliable solution is to select the camera that you want immediately before the new camera before placing.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual• Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
