Visualization
surface painter not working on roof edge
Dave Brach
I a trying to use the surface painter to turn a roof edge from gray to white.  For some reason it will not work on the roof edge.  I can click on any other surface and turn it white but not the roof edge.
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
Which version are you using?
It works for me in Ac28.
Ricardo Lopez
Hi @Dave Brach
Try using Custom Edge Settings:
  1. Clic on the roof edge.
  2. Pet Palette appears.
  3. Clic on Surface and choose from dropping list.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
