2021-03-22 06:13 PM
Solved! Go to Solution.
2021-09-14 02:00 PM
It is the Grid label mentioned above and yes it happens when copied.
another Moderator
2021-09-15 02:59 PM
Hi Eduardo,
Thank you for the information!
I download the object from Podolsky and placing it on various scales. In the PDF output (tried with both printing and publishing), I couldn't reproduce the issue, as you can see in the screenshot below:
(Even with thicker line or if I zoom in the PDF, there was no problem).
Which makes me think, maybe the problem comes from the PDF's Document settings, or with the PDF viewer?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-09-15 04:17 PM
Hmm, try changing the scale of the drawing to a bigger one to see if it happens. I just tried selecting a smaller scale and it looks better.
another Moderator
2021-09-17 03:57 PM
Hi Eduardo,
Per your advice, I played around with line and scale, but couldn't reproduce the issue. If you are interested in a deeper investigation, I would like to have a sample of your project file, where the issue can be reproduced for further testing.
Thank you very much!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
2022-08-19 11:21 PM
Thanks
