2020-02-05 10:54 PM
2020-02-27 04:28 PM
2020-02-27 04:56 PM
Barry Kelly wrote:I meant if one need to for example: Make the horizontal hexagonal bar tilted with the horizontal.
3). Not quite sure what you mean here. For columns, the vertical can be adjusted with the segment height and the horizontal can be adjusted with the taper widths and modifiers in the complex profiles.
2020-02-28 01:57 AM
Braza wrote:No, that can't be done.
I meant if one need to for example: Make the horizontal hexagonal bar tilted with the horizontal.![]()
2020-02-28 02:22 AM
Barry wrote:So I think it is still a good wish. Especially with unordinary or classic column. In my opinion, the main problem is when you add a gdl as a segment you will lose most of options of column .Braza wrote:No, that can't be done.
Something like that would need to be modelled separately.
Even in this example I think I would model the horizontal handle as a separate beam.
2020-02-28 08:12 AM
2020-02-28 07:15 PM
2020-03-01 12:18 AM
2020-03-01 04:31 PM
Braza wrote:You’re welcome, I’m only aware that more complex geometry results in more polygons so keep that in mind. Also, if the geometry is too complex, then the projected 2D appearance can be slow - which is a reason we don’t project all elements. Symbolic 2D is inherently much faster to draw than getting the 2D from the 3D.
Could you tell us if there is any significant decrease of AC performance due to extensive use of this capability?
2020-03-03 09:54 PM
2020-09-28 12:45 PM
