2010-01-11 12:10 AM
2010-01-11 02:52 PM
2010-01-12 10:47 AM
2010-01-12 11:25 AM
2010-01-12 11:40 AM
2010-01-12 11:50 AM
2010-01-12 11:14 PM
laszlonagy wrote:That is correct.
It is a special Wall-Roof relationship, I think.
So the Wall is constrained to the Roof with its height set accordingly, and also SEO-ed.
2022-01-24 06:39 PM - edited 2022-01-24 06:52 PM
This is an essential function and straightforward wish!
2022-01-28 12:54 PM - edited 2022-01-28 03:08 PM
We almost have this feature in Archicad because you can trim a Wall to a Roof so the Roof cuts the Wall and it is an associative relationship. The only thing you have to make sure of is that the Wall height is high enough because in Archicad it will not be set to a higher value if the Roof is elevated.
2022-01-29 12:44 PM - edited 2022-01-29 12:52 PM
Yes - but only almost.
I guess that the majority of cases where one wants a connection between wall and roof and thus use trim to roof has an initial configuration where wall height < roof height. A solution where you first have to manually extend the wall beyond the roof in order to achieve the result is flawed.
