2003-11-01 12:18 AM
2003-11-01 07:31 AM
2003-11-07 04:47 PM
2003-11-07 05:19 PM
Adalbert wrote:You pretty much are describing what Quickviews already does, except for the pen option which I'm not fully convinced about. How would would you input the pen weight of a line that can have multiple pen weights in different layer combos? How then do you do that with 100 lines, walls, etc that can have any combo of line weights. I guess if you could toggle layers to be hairline and true weight that may work.
The followings items should be clearly options set at the later combination
- scale of the combination
-display option of the combination
- text (layer of text to follow combination) for this one need to add a new text toll specific to the combination
- pen settings of the combination.
2003-11-07 05:45 PM
I hate to sound ACADish (which I've never used) but can we PLEASE PLEASE PLEASE install some sort of BYLAYER function into the Layer Combos?
We need to be able to globally change PENS / LINETYPES with an override based on which combo we in. EG. Walls should be BOLD in floor plan (pen defined in plan) yet for HVAC and ELEC should be THIN or even GREYED OUT (color or linetype override)...
2003-11-07 07:45 PM
