Read more
Wishes
Dimension trailing zeros
MarinRacic
I wish Santa would bring me ArchiCAD 9 with one simple option included: "Don't display trailing zeros"! 🙂
It's driving me nuts when I need to have all the dimensions in cm and want to have 1 mm precision, but most of the dimensions are ,0 and only a few really need the decimal number. This option is available in AutoCAD so I don't see why it can't be embedded here... It can very easily be integrated into Options > Preferences > Dimensions menu with just one more check box added.
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
1 REPLY 1
Aussie John
You could use the extra accuracy option and then will only show if there are the "mm" dimensions
Cheers John
[/size]
