2004-02-25 05:53 PM
2004-02-25 06:13 PM
2004-02-25 07:32 PM
oreopoulos wrote:Activate the tool of the object you want to select. Hold down Shift and click with Mercedes on the slab (or the wall, or the line). It selects the object whose tool is active.
It happens to me all the time. I have walls and slabs and lines overlapping.
And say i need to select only the line.
It would be nice, if the object line is active (and another button pressed meaning selection is on and not constuction) clicking at a certain point will pick only the line (slab wall whatever) object.
2004-02-25 07:39 PM
Djordje wrote:I AM FROM THE SAME SCHOOL. SEEMS TO ME THAT AC 7 WAS BETTER AT THIS. IF I HAVE TWO LINES THAT ARE ON TOP OF ONE ANOTHER IT IS NOW VIRTUALLY IMPOSSIBLE TO TOGGLE THROUGH YOUR SELECTION WITH THE MERCEDES SYMBOL TO GET TO THE SECOND LINE (OR FILL, OR WALL…). THE OLD WAY, IF CAPS LOCK WAS ON IT TOGGLED AND VICE VERSA AT LEAST WORKED. AM I STILL MISSIBNG SOMETHING?
I am of the old school that frowns on selecting with clicking around with the arrow tool ...
2004-02-25 08:00 PM
1505Gough wrote:You are missing Caps Lock, as am I. Without it, you must click around in the frowned-upon manner in order to select, e.g., one of two or more coincident slabs. To sort a single slab from a pile, tool-activation works reliably.
AM I STILL MISSING SOMETHING?
2004-02-25 08:42 PM
2004-02-25 09:46 PM
Dave wrote:I think if you only click with the mercedes symbol (versus the checkmark), it will not bring up the pet pallette.
The other problem with the current operation is that it seems you have to keep clicking in fairly rapid succession to keep from entering modification mode, from which you have to ESCAPE and start all over again.
2004-02-25 11:10 PM
2004-02-25 11:24 PM
MMontgomery wrote:You must be using AC 7 or older. With 8.0 (at least the MAC version) and above this shift-click combo doesn't work anymore. Unless I am missing something...
I fyou have multiple lines over each other it will cycle through them.
2004-02-26 04:07 AM
1505Gough wrote:Doesn't cycle for me either
