Can anyone tell me where I can get custom interior elevation markers or if I can create my own that auto generate the elevations? I have found where you can import the custom markers but where can I get them from?????
You can write your own if you know GDL. As the linking between the marker and the elevation for auto referencing is complicated, you would be better off starting with an existing marker, saving a copy of it, and then modifying it. Stating your version of ArchiCAD really helps with this sort of question.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
I am quite familiar with the GDL language but I cannot seem to locate the existing markers to edit. How do I access the GDL code of the existing markers?
I do not know any GDL. Is it beyond possibility for me to create a section/elevation marker that looks like the attached image? If I am able to I would then need to make it available to all of my colleagues as we are all working on teamwork files. This would need to be a very simple process.
Look at the section marker "Section Part Marker_NCS 12", it has one end that looks like your image, the other end is a typical section marker.
Also, please don't double post the same question.
Thanks.
Where do I find this? I tried the 'open subtype' method but it doesn't show up for me. Also, will I be able to make the same marker at both ends?
This section marker is in the US library, perhaps someone with the INT library can tell you if it is there and where it is, if it is in the loaded libraries, then it will be one of the options for the Section Tool > Marker > pop up list for markers. It has the marker you want at only one end, so to create the marker you want will take knowledge of GDL (see my 1st post in this thread).
Signature look good, thanks for taking the time.
