2024-03-06 09:43 AM
In preparing Site plans and conceptual elevations we use Sea Level reference values on Elevation/Level Dimensions. A lot of time goes into changing the Measured value to Custom/Sea Level (4 clicks per item). Dimensions can be copied, already styled, however we prefer Associated dimensions.
Thank you for your great work!
2024-03-08 02:37 AM - edited 2024-03-08 02:37 AM
Not a solution in regards to Favourites but a way to steamline changing the values.
https://community.graphisoft.com/t5/Wishes/Level-Dimension-to-Reference-Level-sea-level/td-p/187268/...
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2024-03-10 04:13 AM
If I remember correctly, from Archicad 26, this is possible in the case of Level Dimensions.
However, it is not available for Elevation Dimensions yet.
