Read more
Wishes
Distinguishing Archicad Icon versions
Rob
This is supposed to be an appeal to a common sense.
The fact that Archicad icon of versions 10, 11, 12 and 13 can not be told apart is teetering on the edge of stupidity. I can not believe we are still struggling with such a basic error in UI design. We do not have the very same icon for two fundamentally different functions in AC itself so along this logic we must not have the same icon for so fundamentally different releases as e.g. 12 and 13 are. I do not have to go to details explaining an impact and consequences of mistakingly opening and resaving a file with different versions.
I believe this is easily fixable even in the next hotfix as it requires just a few hours of one designer (and I know there is a plenty of talented fellas at GS who would fix this in no time).
Customising icons by users is a fairly futile job especially in a big firm environment considering the shear number of installations as well as frequency of hotfixes which revert any icon customisation to default.
This wish has been repeated so many times even during alphas and betas that it is not funny anymore. I am truly annoyed by the current status especially seeing the solution triviality.
::rk
18 REPLIES 18
Absolutely essential.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Or they could just buy them from Ivo Venkov.
Wokka
Or make your own... but what a waste of time...
essential
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
This is an absolute pain! and has to be changed - where's the common sense!?!?
andrewzarb
Here's some I prepared earlier...
Hey I'm happy for Graphisoft to use them!
I made icons with numbers upon them for each version.
Essential!
Thomas Holm
essential
Admittedly a workaround, but Iconographer http://www.mscape.com/ is a free download for the mac. Makes adding numbers to the icons a matter of seconds.
These are my icons for AC.
I wish I could make such for pln files made by different versions!
You can if you do it manually.
You just have to paste an image into the Project Preview of a PLN.
If you do it to your template then all PLN's saved from that will have the same icon.
