Read more
Wishes
Door Leaf Material Passing
vfrontiers
I'd like to be able to pass the DOOR LEAF MATERIALS to a CUSTOM DOOR PANEL I create...
Even if I revise the script and parameters of the leaf to gs_leaf_mat, it does not get passed from the host door...
In addition, if I choose CUSTOM PANEL, the leaf surface parameters are HIDDEN...
I just find two good reasons for this.....
1. I use the same door with different materials in the same file...
2. When trying to use the same panel from project to project, it's hit & miss whether the material ID's match..
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
6 REPLIES 6
Lingwisyer
Guru
Broader wish
vdentello
Whenever you generate a custom leaf from slabs, you'd probably be looking at a couple cprism_{4} scripts inside the custom object´s 3D script.
They'll have a "dumb" building material assigned to them.
By opening it's GDL 3D script, you cant tweak the c_prism{4} to something like this:
cprism_{4} gs_leaf_mat,  gs_leaf_mat,  gs_leaf_mat, 7,
In order for this to work, you have to assign some of the Archicad Library's native surface parameter like gs_leaf_mat or gs_leaf_matin.
This is quite easy even with very little GDL skill.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
Lingwisyer
Guru
I have not been able to get this to work in the past? Can you share an example object of where you have gotten this to work?
As explained in this thread, it is due to the Door Panel Collection call not passing on any parameters.
Ling.
vdentello
Forgot that we must also "comment" or remove the "Set Building Material" and substitute all "bms" with something usual.
GDL Developer
from Brazil
Lingwisyer
Guru
IF not(WIDO_REVEAL_SIDE) then
	!*** default placement
	topmat=gs_leaf_matin
	botmat=gs_leaf_mat
	sidemat=gs_leaf_matin
	sidematedge=gs_leaf_matin
else
	!*** flip
	topmat=gs_leaf_mat
	botmat=gs_leaf_matin
	sidemat=gs_leaf_mat
endIF
sprism_{2} topmat, botmat, sidemat,
	5,
	0,  0, 	1,  0,  framethick, 0,
	0,  0, 	1,  0,  0,  		0,
	-a/2,						R4,		H2, 	sidematedge,
	-a/2 + gs_fw_side_right, 	R3,		15, 	sidemat,
	-a/2 + gs_fw_side_right,	b - R1,	H1, 	sidemat,
	-a/2,						b - R2,	15, 	sidematedge,
	-a/2,						R4,		-1, 	sidematedge
Does it only work with cprism?
Ling.
vdentello
It should work with any command, as long as the default materials are correctly set.
GDL Developer
from Brazil
