2022-11-14 01:45 PM
I'm not sure if this really a wish or just another long standing bug...
When dragging a copy of an existing cloned section marker the new marker setting change to match the host View Map folder. This is kind of ok if you only ever generate a limited number of sections for a single style; but as we can't split cloned folders this means new section marks with different display requirements have to be checked and adjusted every time.
You can't even use Transfer Setting to update the marks.
Surely dragging a copy marker should do just that, create a copy with an incremented ID? This I see as a basic bug fix.
For the future I do think Project Views need to deliver sub folders that can be individually cloned with or without the parent folder.
May be I'm the exception as I am producing literally hundreds of sections with about six different styles according to what I need to display, but even a typical project using cloning must be experiencing similar frustration?
