2010-11-24 03:26 AM
Solved! Go to Solution.
2011-05-06 07:36 PM
2011-05-06 07:36 PM
2018-04-03 03:31 AM
2022-02-04 07:22 PM
I guess for 10 years this issue was never made the priority? It's a bugger to move windows or doors on the wall even with an option to enter dimensions at the pop-up as you have to calculate what dimension to add. It would be nice to see your relative dimensions as you move objects around so you understand where you are at. Yes, you can use guidelines, but that requires extra steps and more of a way around than an actual tool to speed up.
2022-02-07 03:46 AM
But this associated dimension can only be relative to one point?
I don't know how Revit works, but I am assuming you nominate an anchor point.
Archicad already has the ability to be relative to any point you want.
It is not quite what you think but it works well.
You have the tracker that shows you how far you are moving and as you say you can just type in a figure but you have to calculate what that is.
Well, no you don't.
Drag the door (window, object, wall, this works with any element) from the point you want the measurement to be to, and drag it to the point you want the measurement to be from.
Now don't click because that will simply move the door.
Instead type the relative distance you now want into the tracker, followed by a plus + or minus -.
This will add or subtract the distance you type from what the tracker was showing.
Minus to go back in the direction you came from, plus to continue on in the same direction.
Have a watch of this shot movie to see it in action.
Because I am moving a window it is constrained within that wall.
But it works for any element and you can use distance, angle, x, or y and any combination of them to move you element from the point you want to the point you want.
It is not until you press ENTER that the command will be completed.
2022-02-07 05:48 PM
Thank you, Barry. This is a great tip. Will try this.
