sarahric wrote:
so why is there a line tool and a polyline tool, both which can make rectangles? Surely it would be simple to have this information in the line tool.
This is the 3rd cad program I've used and the only one that doesn't do this. I find it also very useful to know the length of a line, and the xy co-ordinates. If it's a horizontal line and y=0 I know it's straight. Also useful.
The line tool actually places 4 separate (but grouped) lines and not actually a rectangle.
The polyline will draw a rectangle but as i said it only needs to have a single node moved or one of the sides altered and it is no longer a rectangle.
So Archicad doesn't seem to care if it is a rectangle or not as it is just a polygon that happens to be a rectangular shape.
I know where you are coming from as I have also used other software.
But once you get used to the Archicad ways thaey are really not all that bad.
I (and I assume most others) would not contruct a plan with single walls or rectanlgles.
Most walls will span over a number of rooms so the overall length may be totally meaningless.
And the rooms may not be rectangular and even if they were there would be no need for individual rectangular slabs or walls.
In other software you would select an existing line to find it's length in an "info" box or similar.
In Archicad just move the user origin (hold ALT & Shift together and wave you mouse over the node you want to measure from).
Once the user origin is set you can then move your mouse to any position and get the X, Y, actual distance and angle in the co-ordinate palette.
It can be the distance between any two points - not just along a line.
And you can measure multiple distances wihtout having to select anything else.
Not the same method but you get the same result.
Then there is the measure tool - press "M" and then click two points.
Or using the tracker you can select your line (wall) and then stretch one end to see the length and angle.
The problem with having the length of a line or rectangle in the info box is that it will only work for a single line or perfect rectangle.
The Archicad way works for any situation.
Sorry for the length of post.
Not ranting - just trying to explain.
