2006-11-24 07:26 AM
2017-10-06 09:46 PM
2021-09-20 07:02 PM
...resurrecting this thread...
Another former acad switcher/beginning Archicad'er here that is wondering about non-print in Archicad...In acad, non-printing layers was a great way to set up drafting conventions to keep a sheet organized. I see, tho, that they are not supported.
What do people do to create nice clean drawings where the notes across details/elevations line up on the page and reference titles have a consistent relative positions.
I'm doing my first project, and I'm frustrated by the apparent looseness of placing views on sheets just eyeballing things...is there a dimensionally accurate process for these things?
Followup drafting convention question: When working in 2d for details & interior elevations, is it conventional wisdom to create individual views (1 per dtl, or 1 per int elev) or just draw whatever 2d views on a sheet layout as a single view (like all four sides (int elevs) of a given room)? Or even all the interior elevations on a sheet view?
Thanks for your patience with these very basic questions.
2021-09-21 12:10 AM
@proto Chuck gave one response in the last post before yours - Trace Reference, Guidelines, etc.
But, of course, any layer that is not on is non-printing at print time, right? 🙂
So, you can certainly use layer combinations when you are looking at layouts if you really must have actual guidelines/etc or some type of template to snap to... but you can also use the hotspot tool to place snappable hotspots in a Master that are viewable in all layouts using that Master. Hotspots never print. Ditto guidelines as Chuck suggests.
Layer combinations for the layout (including the Master) have no impact on placed drawings.
"Never" draw anything related to the project when you are in layout mode. For the details and interior elevations etc you want things to be 'live' and derived from the model as much as possible, so, yes, a placed view (which becomes a 'drawing') for each detail and elevations.
2021-09-21 12:28 AM
hotspots - how do these get used? [i did look them up, so I understand what they are but do not understand this new strategy for documentation...maybe just an example, i'm guessing there are many ways to use them...]
"Never draw anything related to the project when you in layout mode."
OK, but how do people coordinate between details/elevations that end up sharing space on a layout?
ie notes lining up, avoiding linework overlapping, coordinating sizes/shapes of views that will share space on a sheet
i'm familiar w/ guidelines from Adobe products & those make sense
i understand how trace works, but not sure how trace applies to this issue of layout coordination
thanks for your assistance,
2021-09-22 02:47 AM
If you go to the Master Layout Settings, check out the "Drawing Placement" panel, which has two options for the automatic placement of Drawings on Layouts. Here is the Help Center page discussing them:
https://helpcenter.graphisoft.com/user-guide/137577/#XREF_22630_Arranging_Multiple
https://helpcenter.graphisoft.com/user-guide/137981/#XREF_69281_Auto_Arrange_New
https://helpcenter.graphisoft.com/user-guide/137981/#XREF_13489_Align_and_assign
2021-09-22 10:19 AM - edited 2021-09-22 10:22 AM
@proto For manual placement you can drop your layout views on the sheet and then you can either move/drag the views with the "viewport" corners or you can use points within the view as base and reference points.Make sure you use the correct Move option from the context menu, one moves the whole "viewport" the other option repositions the view within the "viewport"
2021-09-22 05:19 PM - edited 2021-09-22 05:24 PM
Not sure this is really addressing the issue [aligning content between views, as opposed to just getting views to be organized on a layout], but I will read up on these & see what I am missing, thank you, laszlo
2021-09-22 06:32 PM
For aligning content between two Views or a View and a Drawing placed on a Layout, the Trace Reference is the best tool.
2021-09-22 06:33 PM
Thanks, Laszlo, I will go back & review that tool more thoroughly.
2021-09-22 10:50 PM
OK...Trace is a revelation!
That's what I needed...
