2024-05-13 06:43 PM - edited 2024-05-13 08:21 PM
Would like to see better dimensioning features, including:
1) Would like ability to easily change a single-wide unit to a 2- or 3- wide unit. Currently, you have to select a different library part then reset all the information (size, styles, plan display, etc...).
2) The ability of the user to create pre-set size options that correspond with window manufacturers' standard sizes. Currently, the only way I have found to preset sizes is to save a ton of Favorites.
2024-05-14 03:29 AM
1. Press Ctrl + Alt when selecting the new library part to copy existing common parameters.
2. A wish for a txt file input where the object will read preset sizes from?
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
