2024 Technology Preview Program
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
window label in elevation
Dave Brach
There used to be a checkbox in the window infobox "label window" to add a label in elevation. It has since disappeared. Please bring it back
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
The checkbox has gone.
Labels work differently now from version 19.
Set the label you want in the label tool and then just click on your window (plan or elevation).
You can now have multiple labels on an element.
David Maudlin
Dave:
Another way is to set the Label, then select all of the Windows to be labeled, then use the new Label Selected Elements command.
If you are using AC20, then you can update your signature.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
