RWARCHPC
BIMx with live design options in Archicad 28
Is it possible to publish a BIMx model with alternate design options such that one cab toggle through various options as in a live Archicad (28) model? I recently tried by setting up 3D views with alternate design options in the publisher, but when I opened the BIMx model, the design option components were simply blank. It appears that it is possible, according to a post by Roland Szabo from April 2024, but I have been able to publish to BIMx with active design options.
Robert Wilkanowski
Archicad 29
Mac OS '15 Sequoia
Hardware: M4 Max with 16-core CPU, 32-core GPU, 40 core GPU, 16-core Neural Engine, 64GB unified memory
1TB SSD storage
1 Solution
Sefa Yakut
You can save your design options as a view. If you publish these alternatives after that you can change them from BIMx.
Go to post
1 Reply 1
Sefa Yakut
