Importing into 3d Max disastrous please help
Please Help
After two weeks and many hours lost
- we cannot export our ArchiCad (22) models successfully to 3d max.
All the elements are singular when importing the model into max for rendering.
We did do layer management on our archicad models.
Please help
do we have to model our whole scheme
in revit again!!?
Thanks in advance for your help
2 REPLIES 2
Eduardo Rolon
Try other options like Collada, OBJ or SketchUp.
If all else fails look for the TwinMotion installer which will add FBX as one of the export options which should help.
Another option is to "rent" modelport
https://archvista.com/modelport/
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Lingwisyer
Guru
What do you mean by singular? As in faces? What format are you using? We have sent 3ds models to others previously with no apparent issue.
https://helpcenter.graphisoft.com/knowledgebase/25540/
Ling.
Learn and get certified!
