Converting files
Red
Can a tif file be converted to a dxf or a dwg? If so what program do I need to use.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
4 REPLIES 4
A TIFF file is a bitmap: a two-dimensional array of differently colored pixels. DXF and DWG are files composed of vectors: lines and shapes described by geometry, which could be in three dimensions. I don't believe you can just turn a TIFF into one of those other file types. You could trace over the lines in a TIFF to create the vectors that make up a DXF or DWG, or perhaps place a TIFF into a DWG or DXF (not sure about that one).
Djordje
You need to use a vectorizer - something like Adobe Streamline of yesteryears. Check the software by Consistent Software, the makers of Plan2Model - they also have a pretty smart vectorizing software.
What exactly do you need to do?
Manual tracing is always a (time consuming) option. Then again, correcting the vectorized file is time consuming, too.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
It is about time that ArchiCad had its own vectoriser built into the program.
The CAD program I use at work has had one included for the last 2 versions. It also lets you explode text.
I suppose this should be added to the wish list.
stefan
Wintopo Pro
http://www.wburrows.demon.co.uk/softsoft/wintopo/index-pro.htm
Wintopo Freeware
http://www.wburrows.demon.co.uk/softsoft/wintopo/index-free.htm
Archicad-user since 1998
my Archicad Book
