ā2005-09-08 08:58 AM
The wrote:This would interest many people in the discussion around MaxonForm.
Main Improvements in Revit Building 8.1:
Considering that it is just a point release, Revit Building 8.1 packs a surprising number of new features. To start with, it enhances the Building Maker functionality for conceptual design mentioned in the previous section by enabling the import of NURBS surfaces from other applications in the form of DWG or SAT files. These can be turned into mass objects in Building Maker, after which you can create roofs, walls, floors, and curtain systems from selected faces (see Figure 5-a). A separate but related ability is the creation of non-vertical walls from massing components, created within Revit Building or imported from other applications (see Figure 5-b). These non-vertical walls behave like the regular walls: you can place doors and windows in them; they can be joined to other walls; they appear properly cut in plan views; they are correctly listed in schedules; and they can be exported along with their information to ODBC and other formats. Considering that Revit Building lacks a good set of freeform modeling tools, these new capabilities make it easier to bring conceptual massing models created in other applications into Revit Building and convert them into building models rather than having to start from scratch.
http://www.aecbytes.com/review/RevitBuilding8.htm
ā2005-10-31 10:02 PM
Chazz wrote:While I agree, some people are more likely to upgrade to Revit based on existing systems, that does not mean that they are "lined up to migrate." There's a big difference between the two.Djordje wrote:Am I sure? Well, yes.Chazz wrote:Are you really sure of this?
Perhaps more importantly, they have an astronomical user base all lined up to migrate.
Why is the ADT then given free, why didn't the astronomical user base migrate already?
ā2005-10-31 11:46 PM
Rashid wrote:The people making the decisions about Revit, and the direction to take it is almost entirely in the hands of Architects. The Revit Building Product Manager is an architect. The "Number 3" guy from the early days of Revit is an Architect, below the two founders, who were Russian mathmaticians from PTC. Most of the development team is architects. Phil Bernstein, the vice president of the Building Solutions Division of Autodesk, which Revit falls under, is an architect, and a professor at the Yale University of Architecture. So, yes, the Revit team has a team of talented programmers...because they must figure out how to make Revit do what all these architects want!
Revit currently looks as if run by talented programmers and marketers while ArchiCAD by talented Architects, notorious for being slow to adopt new methods. Ironically they were 15 years ahead of Revit.
ā2005-11-01 08:50 AM
ā2005-11-01 02:16 PM
relationships,i can taste this using the 'accessories' ...i which i could select the exterior wall for example and have them be an 'accessory' of the 'slab'.
ā2005-11-02 05:54 AM
Chazz wrote:Hm ... we can continue this in the Pub if you like as the point is very far off the software discussion, and cannot be called politically correct in the broadest sense of the word. Whether something is Russian, American, Serbian, or Martian is irrelevant - it works for you or not, that is the bottom line!
Am I sure? Well, yes. My assertion is simply that these users (and I'm talking only about architects and their ilk, not the billions of surveyors, mechanical engineers, etc using Autocad) are going to be much more predisposed to migrate to Revit than something called ArchiCAD (wait a minute, I've heard of that, it's from Russia, right?). That predisposition is all it takes. Having a single-vendor upgrade path is an incalculable advantage. Having the new product (Revit) maintain close ties to your old one -AutoCad- makes it that much more reassuring to the migratee.
ā2005-11-02 10:24 AM
ā2005-11-02 10:53 AM
ā2005-11-02 10:58 AM
ā2005-11-02 11:28 AM
ā2005-11-02 11:44 AM
Petros wrote:I can say a few things about generative components:
I just saw some pretty interesting videos regarding the london city hall
at
http://www.fosterandpartners.com/
it seems they use some generative components from triforma which seems to handle geometric relations between generator lines,arcs etc of the building.
IMHO it is more critical to make use of design rules in testing preliminary geometric form relations than searching for relations between slab-wall etc .
Petros
