2015-08-25 09:45 PM
2015-08-25 11:54 PM
2015-08-26 02:22 AM
2015-08-26 10:08 AM
sinceV6 wrote:When something is modeled as a morph it is probably because there is no other option. It was probably some other element that was converted to a morph for the sake of editing some thing that can not be done in any other way. The down side is that you can not get the top surface area of a morph into a schedule. And, that is not the only quantity I need for the morph element in a schedule. I don't want a bunch of separate schedules. One for top surface area, one for volume, etc.... I want one schedule that has three very simple things. ID, Volume, Top Surface Area. And I want to extract that data from one element, not 2 or three by virtue of using 3 or 4 solid element operations. That is not too much to expect from ArchiCAD.
Hi.
I see you are in v19. Why don't you use the new surface schedules? You could easily set the criteria needed to show the area of a certain material you assign to the top surfaces of your driveway...
Also... not entirely sure, but I think the Area By Story works only if your morph is solid so AC can slice though it on each story.
(oh... and I think the pictures for area and volume are swapped in the help
http://helpcenter.graphisoft.com/guides/archicad-19-int-reference-guide/views-of-the-virtual-buildin...
Best regards.
2015-08-26 02:52 PM
sinceV6 wrote:Thanks for the heads up on this, we've fixed it now
...(oh... and I think the pictures for area and volume are swapped in the help...
2015-08-26 07:23 PM
James wrote:And what is your experience James, with getting the top surface of a morph into a schedule? Can this be done or not? I can't do it so I assume that no one else can either but I am hoping there is some way to do this.sinceV6 wrote:Thanks for the heads up on this, we've fixed it now
2015-08-26 09:11 PM
2015-08-26 11:08 PM
ejrolon wrote:Does it? What you get when you schedule "area" of a morph is not the top surface area. Your schedule is probably showing the entire surface area of the morphs. Check and see.
mine does. so it must be something else
2015-08-27 05:28 AM
sinceV6 wrote:That much is correct. I can always get what I want from ArchiCAD one way or another.
... I assume you can get what you want with schedules.
2015-08-27 10:11 AM
2015-08-27 05:44 PM
