Schedules and mod files
rgarand
I have done a search and nothing seems to come up. I have also searched the help section of the book, so here it goes...
If I link my .mod files to my .pln file, will my schedules, in my .pln, see my doors/windows etc. which are within a .mod file(s)?
Seems like it should work...but we can not seem to get it to work?
Any comments?
Thanks,
Robert J. Garand
ArchiCAD USA 27-Build 5001 USA FULL
Windows 10 Prof (64 bit) - Intel i9-10920X CPU 3.50 GHz - 128 GB RAM - NVIDIA Quadro RTX 5000
1 REPLY 1
Elements within hotlinked .mods should schedule exactly as local elements. For some reason you can include/exclude hotlinks from Find&Select but you cannot from Schedules even if you want to, at least in 11. So I would guess there is some problem with your schedule settings.
Does your schedule work if (you make a test copy of your file and) break your hotlink --select the hotlinked module, File>External Content>Hotlinked Module Settings, check "Break hotlink of selected modules"?
