Data Exchange articles
Articles
Automatic Live Load Generation
Table of Content Zones can be used for much moreDerive imposed loadsWhich zones generate live loads?1. Check the architectural model2. Check Zone Classifications3. Check Load CategoriesAdjust Load Categories inside ArchicadAdjust Load Categories outs...
EmokeCsikos_0-1653068947878.png EmokeCsikos_1-1653068947883.png EmokeCsikos_2-1653068947885.png EmokeCsikos_3-1653068947888.png
Faster Export to FRILO
Frequently exporting SAF files to FRILO can be time consuming Structural engineers who use FRILO are currently spending quite some time exporting SAF files by selecting a save location and setting the path for export each time, which interrupts the w...
MoaazHassan_0-1653304653486.png MoaazHassan_1-1653304653488.png MoaazHassan_2-1653304653489.png MoaazHassan_3-1653304653492.png
SAF Translator Improvements
Adjusting SAF Translator settings Currently, structural engineers can create and adjust structural analytical models in Archicad and eventually export them to the structural analysis software via SAF translators. However, in earlier versions of Archi...
MoaazHassan_0-1653306242486.png MoaazHassan_1-1653306242492.png MoaazHassan_2-1653306242497.png MoaazHassan_3-1653306242499.png
Support of Multi-Segmented Columns and Beams
Graphisoft has focused on further streamlining multi-disciplinary design workflows. Archicad 26 enhances the collaboration between structural engineers and architects with important structural analytical workflow improvements. Structural elements wit...
GabrielDantas_0-1653306781866.png GabrielDantas_1-1653306781870.png GabrielDantas_2-1653306781872.png GabrielDantas_3-1653306781873.png
Structural Analytical Model Exchange
Archicad can share the structural analytical model with any external finite element analysis software that supports open-source file formats optimised for this purpose, such as: Structural Analysis Format (SAF) IFC Structural Analysis View (IFC SAV) ...
wp-content_uploads_2020_07_analytical-openbim-2-NEW-1.png wp-content_uploads_2020_07_SAF_Translator_Export.jpg wp-content_uploads_2020_07_SAF_Translator_Import.jpg
Integrated Structural Analytical Model
The integrated structural analytical model within Archicad helps architects and structural engineers achieve real collaborative teamwork. This capability is available as of Archicad 24. While architects design with the help of physical models (BIM), ...
wp-content_uploads_2020_07_IntegratedSAM.png wp-content_uploads_2020_04_Physical-Model-with-Integrated-Structural-Analytical-Model.png wp-content_uploads_2020_07_analytical-openbim-2-NEW.png wp-content_uploads_2020_04_Integrated-analytical-model-generated-within-the-defined-physical-model.png
Top Contributors
