Maybe this will help?
https://archicad-talk.graphisoft.com/viewtopic.php?f=10&t=59277
Also read the Helpcenter link
There was a stair bug with build 5010 that is supposed to be fixed now.
Not sure if that is the problem with your custom door panels but the Helpcenter article does mention a problem with other object becoming available a s custom stair objects.
I noticed I had a file just the other day will missing stairs but I have not yet gone through this process to see if it helps.
Your custom doors should be saved as objects in your embedded library.
If they are not there then they will need to be in a library that is being loaded otherwise they will not be available in the file.
But maybe the stair fix will be the answer if they are in the embedded (or loaded) library.
