Design forum
Why is there a stair finish in CORE ONLY?
LeeJaeYoung
Q4. Why is there a stair finish in CORE ONLY?
AC25 5010 / AC26 4019 on window 11
Andrii Levko
Hi Lee
Because at the moment you have probably library object for Tread and Rise. To have Rise and Tread hidden with Core Only, you need to set it as profile. Archicad has the default profile "Stair Tread 300 for Riser Slanted 150", and it is set "finish" by default.
Andrii
AC 8.1 - 25 INT/POL 5010
11 REPLIES 11
Andrii Levko
Hi Lee
Andrii
Thank you so much ^^
When I do as you said, the above happens.
How can I solve this?
It seems to be intersectional issue. Maybe you have hide some element with stronger priority.
Andrii
This is just a change.
I think graphicsoft can solve it with IF statement in gdl enough, but I was wondering why they didn't solve it until now.
why why why ^^
Built-in Tread or Riser
IF GLOB_STRUCTURE_DISPLAY <> 1 THEN
call "basicStairTread_m" parameters all bOverrideStructureSurface = ac_bOverrideStructureSurface,
treadSurface = ac_treadSurface
ENDIF
It's a bit strange. Looks like a bug.
Andrii
Are you saying that you shouldn't use the IF statement?
I meant your screen with the wrong height of the top rise, when you switch on "End with Riser". Looks like a bug.
Andrii
1. You made me switch from End Riser to End Tread.
2. So I have to use SOE.
3. And adding an if statement seems to be a better solution than adding an if statement to the profile.
Your answer raised a question about 2D.
If possible, we would appreciate it if you could check the questions below.
https://community.Graphisoft.com/t5/Design-forum/I-want-to-erase-the-lines-on-both-sides-of-the-last... M161761
Didn't find the answer? Start a new discussion
