strange behavior with fill on steel beam object
Achille Pavlidis
So when applying a fill on a steel beam object, the pen color appears fine if the beam is horizontal.
But once it gets rotated to say, 45 degrees the pen turns black and there is no way to change this...
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
3 REPLIES 3
Same thing here!
Yes, it looks like if any value other than zero (0) is entered in the Rotation Angle field, the object uses the Contour Pen isntead of the Fill Pen.
I will report this to Graphisoft.
That is probably because it is going from a scripted 2D view with the proper pens when horizontal to a "PROJECT2" view when rotated.
Learn and get certified!
