GDL
How can I set the GDL Editor Background Color?
LeeJaeYoung
How can I set the GDL Editor Background Color? It's too bright ㅠㅠ
My hope is that the text is white and the background is black
I know window 11 thema setting.
but I can't see the text in the parameter....
AC27 on window 11
4 REPLIES 4
Peter Baksa
That is not possible. Setting a brighter background color might help.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
LeeJaeYoung
thank you so much. ^^
AC27 on window 11
@Peter Baksa Blue on black throughout the AC dark mode environment is really bad to read. If you could give someone a nudge in the UI Department to get it changed to cyan it would be appreciated.
Guru
There are a few wishes around requesting an update / revamp of the AC IDE that have been around for years...
Here are a few
https://community.Graphisoft.com/t5/Wishes-forum/an-improved-GDL-editor/m-p/114945
https://community.Graphisoft.com/t5/Wishes-forum/GDL-Editor-Again/m-p/305747
https://community.Graphisoft.com/t5/Wishes-forum/Visual-GDL-editor-again/td-p/223720/page/9
There is probably one somewhere that specifically mentions the workspace colour.
Win10 | R5 2600 | 16GB | GTX1660
