monster
AC20 3d section BUG
We have just (yesterday) moved to AC20 INT 3012.
Unfortunately I've found first annoying bug (?).
When I shift 3d section plane on floor plan and go back to 3d window,
section doesn't move (doesnt redraw).
I have noticed that it will only work when I close 3d window and reopen it.
In AC19 I didnt have to close 3d window.
Is it planned change or BUG?
Regards,
Pawel
4 Replies 4
In the Elevation Settings Dialog what is the "Status" field set to?
It will update automatically only if it is set to the "Auto-rebuild Model" option. With the other two options you have to update it manually.
monster
'Auto-rebuild Model' option is Set.
It only rebuilds: Elevation, Section, 3d window when I close it and reopen.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Hi Pawel,
A user in my region previously reported this to Technical Support and it was entered as a bug. It should be working properly again soon with the first mainstream Update for ARCHICAD 20 set to be released this Fall. Sorry for the inconvenience.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Katalin Borszeki
HI, yes, this has been corrected in build 4009! Best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
