AC27 Slow Trace Reference on Worksheet
Harvey Fontanilla
Hi. We are currently experiencing slow navigation (zooming, placing text, dimensions) when doing worksheets. Our typical workflow is:
For Blow-up Plans (Toilet Details, other details with larger scale than our plans and will only require a portion of the plan):
After placing the blow-up views, we trace the layout on a separate worksheet then from there, we place our dimensions. This Worksheet will now be placed on top of the Traced Layout so we can have a separate view showing only text, tags and dimensions instead of placing it on the model space.
Since Archicad 27, we cannot do this anymore efficiently due to the "short" stops. Even when panning or selecting text when using worksheet with trace reference, this happens. Worksheets with Trace Reference becomes so slow.
We did not encounter this on all the previous versions we had since AC18. Do you guys know a quick solution for this or had encountered this?
Thank you!
30 REPLIES 30
So problem solved by changing GPU.
From Radeon RX 570 to (older and weaker) GeForce GTX 750 Ti.
