2024-02-16 03:33 AM - last edited on 2024-02-16 07:27 PM by Laszlo Nagy
Hi to all,
Has anyone encounter this issue within the layout of Archicad 27 (build 4060) Teamwork?
It seems even if I cropped the drawing view it still shows those text that I want to hide, am I missing anything here?
See image below.
Zoomed out
Zoomed in
Any help would be greatly appreciated.
Thanks!
Solved! Go to Solution.
2024-02-19 07:36 AM
Yes, that's an actual issue, but if it helps, I can tell you that when publishing it to PDF those hidden figures are not visible. I mean the issue appears only in the workspace but not in the published product.
2024-02-16 04:59 AM
Seems to be an issue.
https://community.graphisoft.com/t5/Documentation/AC27-Text-NOT-Cropping-in-Layout/m-p/572565
Be sure to report it to your local support.
2024-02-16 08:22 AM
I was trying to look in the forums if someone got post this issues but didn't manage to find it. Thanks for the link @Barry Kelly seems to be an issue already last year and now got new update but still haven't resolve. I will inform local support here about this issue. 😎
2024-02-19 07:36 AM
2024-02-19 08:03 AM
Thanks! Haven't tried publishing though I was thinking of reverting back to AC 26. (painful process setup teamwork and all) but since you mentioned it won't appear when publish maybe I can try to ignore this issue.
2024-02-19 03:37 PM - last edited on 2024-05-23 07:12 PM by Laszlo Nagy
I had the same problem. By setting fit frame to drawing to manually resized frame and then switching back to fit frame to drawing, everything was ok again. Not the most durable solution.... But it worked
2024-04-03 03:18 PM - last edited on 2024-05-23 07:12 PM by Laszlo Nagy
I guess this problem could be solved somewhere through editing the settings of the work enviroment but can´t find the way to do it. I croped a drawing and it still display the numbers of the measuring outside the croped area. How do I do so they don´t appear?
EDIT.
This is a new post merged with an old thread on the same subject.
2024-05-15 08:22 PM
Does anyone know when this will be fixed?? Is it on Graphisoft's radar?
2024-05-23 07:13 PM
Do you by any chance have your model located very far from the Project Origin?
If so, that could be a cause for this phenomenon.
a month ago
Hi Laszlo,
I have placed the model near the origin.
