2024-06-30
10:32 AM
2026-01-15
07:15 PM
Gordana Radonic
When i export a plan to autocad, all labels that uses GDL are not exported correctly , the text alignement is wrong,
Here is the Zone label , and it's settings
In autocad, it looks like that :
it's imported as a Block,
When i open the block , the text anchor points are in the middle , where they should be, and the text alignement parameter is set correctly to " Center" :
i noticed there is some extra "space caracters in the text field , :
When i delete that extra spaces, it looks correct,
Does someone knows this issue and how to fix it ??
3 weeks ago - last edited 3 weeks ago
I wonder what it is that is suffixing everything with a whole bunch of spaces... I had forgotten about this, and someone told me recently that I had told them to use autotext instead of zone labels and I was wondering why... Annoying this is that autotext used your Calculation Units rather than your Dimension Units...
